od spiky246 v úterý 16. 2. 2010 22:35:25
Su to dobre parametre ak chcem na tom pozerat filmi a hrat hry??
projektor by bol vzdialeny od platna asi 2.5-4m na dlhom asi 2.5m///
Ide mi hlavne o ten kotrast,,,nerozumiem sa velmi do projektorov,,,takze preto..
Display Technology: DLP, Digital Light Processor
Native Resolution: Native 720p (1280×720)
Compressed Resolution: Maximum UXGA (1600×1200), 1080p (1920×1080)
Typical Colors: 1.07 Billion Colors
Brightness (ANSI lumens): 2500 ANSI Lumens (Standard), 2000 ANSI Lumens (ECO)
Contrast Ratio: 3200:1
Throw Ratio: 58″ at 2 meter distance (1.55 ~ 1.70:1)
Noise Level: 32 dBA (Standard mode), 27 dBA (ECO mode)
Lamp Life: 3000 Hours (Standard), 4000 Hours (ECO)
Lamp Type: 200 W user replaceable P-VIP lamp
I/O Connectors: Analog RGB/Component Video (D-sub) x 1 Composite Video (RCA) x 1 S-Video (Mini DIN) x 1 Component (3 RCA) x 1 HDMI (Video, Audio, HDCP) x 1 PC Audio (Stereo mini jack) x 1 RS232 (Mini DIN) x 1
Dimensions: 268 x 192 x 80 mm (10.6″ x 7.6″ x 3.1″)
Weight: 2.2 kg (4.9 lbs)
dakujem
