I've been playing with the new DivX subtitle support.
On the good news, it does actually work and we can now display softsubs with our videos, even Xvid videos. Each subtitle track has it's own language code and you will see these in the PS3 UI as you cycle thru them. The subs were disabled by default so you have to click the subtitle button once to get them showing up. Maybe there is a setting in the .divx format that specifies if a track should be shown be default.
However, to get it to work you have to remux your Xvid .avi file + .srt file into a .divx file. The .srt will be converted to a bitmapped subtitle format. You can also use an idx/sub format which is already a bitmap thus saving one step. But you must remux it into a .divx file.
I've never tried muxing any subtitles into .avi files so I can't say whether that works or not.
This does work:
Xvid/Divx .divx with internal XSub
I can say that these formats do not work:
Xvid/Divx .avi + external .srt
Xvid/Divx .avi + external .idx/.sub
AVC .mp4 with internal TTXT
ASP .mp4 with internal TTXT (does not play at all, as in previous firmwares)
I tried using both Sup2DivX and DivxMuxGUI. Sup2DivX is the only one that I could get to work.
NOTE TO SONY: This is great but get .srt subtitles working! I don't wanna remux anything into the .divx container. I'm constantly translating/editing my subtitles so external .srt subtitles are a big help.
st39.6 píše:d.f.h > no, to JE podpora titulku. Btw kdyz uz, tak tohle uvitam mnohem vic. Pokud dneska stahnes nejakej HD rip s titlema, ve vetsine pripadu sou namuxovany.
No dobře, ale každý si pod pojmem "podpora titulků pro DivX/XviD" představí to, co umí každá plečka z Tesca - textové .sub a .srt titulky A neříkej, mi, že ne.
st39.6 píše:nerikam ze ne. reagoval sem vyhradne na "tohle neni podpora titulku"
Martin píše:ví se co je a k čemu je "Mosquito Noise Reduction"?
http://www.us.playstation.com/PS3/About ... pdate.html
d.f.h píše:Martin píše:ví se co je a k čemu je "Mosquito Noise Reduction"?
Eh, no... Já začal louskat tohle: http://www.videsignline.com/showArticle ... =180207350 a nakonec to prostě beru tak, že se Mosquito Noise Reduction snaží eliminovat kompresní artefakty. Na tohle fakt nemám hlavu
