Serie HDTV 2009 od Panasonicu
Příspěvekod kolemjdoucí v čtvrtek 8. 1. 2009 9:15:45
Zdravím, jestli někdo váhá jestli si pořídit loňské řady nebo koupit to. co Panasonic chystá pro letošní rok, tak může porovnávat.
Z1 Series
The flagship VIERA plasma in 2009 is the Z1 series, with a revolutionary one inch thin panel design and Wireless HD connectivity to deliver the ultimate sleek, uncluttered HDTV viewing experience. Also included on the VIERA Z1 is VIERA CAST web menu with the new streaming HD movie rental capability via Amazon Video-on-Demand. The Neo PDP design of the VIERA Z1 produces a brighter picture, deeper blacks, improved native contrast ratio (40,000:1) and Full-Time 1080 TV lines of motion resolution. Other Z1 model features include;1080p resolution, a THX Certified Display; an Infinite Black panel; 600Hz Sub-field Drive; and VIERA Linkä, and VIERA Image Viewer for playing back digital still images and AVCHD videos recorded on SD Memory Cards. The Z1 series will be available in the summer of 2009 in the new TC-54Z1, 54-inch class screen size (54” measured diagonally).
V10 Series
The VIERA V10 series are slim, 2-inch thin plasma HDTVs with built-in tuners. The V10 series offer such cutting edge innovations as Digital Cinema Color™ which helps to deliver all movie-essential colors, full THX Display certification, and the VIERA CAST web menu with Amazon Video on Demand services. The Neo PDP design of the V10 series features 1080p resolution; deeper blacks, improved native contrast ratio of 40,000:1; Full-Time 1080 TV lines of motion resolution; an Infinite Black panel; 600Hz Sub-field Drive; VIERA Link, and VIERA Image Viewer for playing back digital still images and AVCHD videos recorded on SD Memory Cards. The V10 series is available in a 65-inch class (64.8” measured diagonally), 58-inch class (58” measured diagonally), 54-inch class (54” measured diagonally), and a 50-inch class (49.9” measured diagonally) screen size. The 50-inch model with one-sheet-of-glass design will be available in May 2009 and the remaining models will be available in the summer of 2009.
G10 Series
The VIERA G10 Plasma series include features like the VIERA CAST web menu, a THX certified Display, and VIERA Image Viewer for playing back digital still images and AVCHD videos recorded on SD Memory Cards. The NEO PDP design of the G10 series also offers 1080p resolution, deeper blacks, improved native contrast ratio of 40,000:1, Full-Time 1080 TV lines of motion resolution, an Infinite Black panel, 600Hz Sub-field Drive, as well as Game Mode and VIERA Link. The G10 series will be available in a 54-inch class (54” measured diagonally), 50-inch class (49.9” measured diagonally), 46-inch class (46” measured diagonally), and 42-inch class (41.6” measured diagonally) screen size. The 42-inch, 46-inch and 50-inch HDTVs will be available in March 2009, while the 54-inch model will be available in May 2009.
S1 Series
The VIERA S1 Plasma series offers a broad range of HDTVs which also represent the first VIERA plasma series to feature the new NEO PDP designs. Key features of the S1 series include Full-Time 1080 TV lines of motion resolution, which eliminate traditional HDTV motion blur. The S1 series also feature THX certified displays together with VIERA Image Viewer. Other features include 1080p resolution; a native contrast ratio of 40,000:1; an Infinite Black panel; 600Hz Sub-field Drive; and a Game Mode. The S1 series will compliment the V10 65” screen size with its own 65-inch class (64.7” measured diagonally) product. Other S1 sizes include a 58-inch class (58” measured diagonally), a 54-inch class (54” measured diagonally), a 50-inch class (49.9” measured diagonally), a 46-inch class (46” measured diagonally), and a 42-inch class (41.6” measured diagonally). The 42-inch, 46-inch and 50-inch HDTVs will be available in March 2009 while the 54-inch will be available in the summer of 2009.
X1 Series
Panasonic’s focus in 2009 continues to be on high definition 1080p HDTVs but the VIERA X1 series represent a line of 720p plasma HDTVs which help Panasonic deliver on its promise to satisfy consumer demands for differing HDTV resolution options. The X1 VIERA HDTVs offer stunning picture performance with a 600Hz Sub-field Drive that delivers razor-sharp motion focus, VIERA Image Viewer for sharing digital photos with friends and family, and VIERA Link control of all compatible A/V home entertainment components via a single remote. The X1 series also feature improved native contrast ratio of 30,000:1, an Infinite Black panel, and a Game Mode. The VIERA X1 plasmas are available in a 50-inch class (49.9” measured diagonally) and 42-inch class (41.6” measured diagonally).
http://www2.panasonic.com/webapp/wcs/st ... 9012646554
http://panasonic.net/avc/viera/
http://www.engadget.com/2009/01/07/hand ... co-plasma/
kolemjdoucí
Re: Serie HDTV 2009 od Panasonicu
Příspěvekod Nick007 v čtvrtek 8. 1. 2009 14:09:06
Je to trošku, jak jsem očekával, místo zásadních inovací vtrhne do plazem web. Pro mě k ničemu. Ještě Deeper Color, hlavně že jsou už všemi podporované. No, nechci předjímat (a samozřejmě jakožto majitel poslední generace doufám), ale pochybuji, že se obrazová kvalita znatelně zlepší.
Příspěvekod kolemjdoucí v čtvrtek 8. 1. 2009 14:56:25
Sakra v tom ranním chvatu ( stejně mi ten bus ujel ) jsem přehlédl, že to jsou tv určené pro trhy v USA, takže to porovnávání beru zpět, jak to bude s dostupností jednotlivých řad v našich končinách na to si budou zájemci muset počkat, omlouvám se. :oops: :oops: :oops:
kolemjdoucí
Příspěvekod kolemjdoucí v úterý 13. 1. 2009 10:45:06
Jenom doplním řadu X o typ PDP TH-P37X1
http://translate.google.cz/translate?hl ... cs%26lr%3D
Dle zástupce Panasonicu na CES 2009 by nové řady měly mít lepší černou
http://ces.cnet.com/8301-19167_1-101370 ... ncol;title
kolemjdoucí
Příspěvekod kolemjdoucí v úterý 3. 2. 2009 14:07:09
Pro úplnost dodávám, že Panasonic dnes v Japonsku uvedl další modely svých HDTVs, série Z, V,G.
http://translate.google.cz/translate?pr ... ry_state0=
kolemjdoucí
Příspěvekod Martas v úterý 3. 2. 2009 15:32:57
Mohl by mi nekdo spocitat kolik ta tv stoji v korunach kdyz ma stat 40 milionu jenu.Sem uplne blbej to priznavam ale porad mi vychazi nejaky hausnumera diky moc. :)
Martas
Příspěvekod Nick007 v úterý 3. 2. 2009 18:09:57
Martas píše:Mohl by mi nekdo spocitat kolik ta tv stoji v korunach kdyz ma stat 40 milionu jenu.Sem uplne blbej to priznavam ale porad mi vychazi nejaky hausnumera diky moc. :)
Podle aktuálního kurzu 9 879 200,-
Příspěvekod tomiisek v úterý 3. 2. 2009 18:39:12
Nick007 píše:
Takže zítra touhle dobou bude stát přes 10 mega :|
Jinak bacha na větší nákupy, do 150-eurového bezcelního limitu se každým dnem vejde méně a méně zboží :|
Příspěvekod Martas v úterý 3. 2. 2009 19:38:27
Tak nejak mi to vychazelo tak sem myslel ze jsem se splet :D
Martas
Příspěvekod kolemjdoucí v úterý 3. 2. 2009 23:35:43
Za použití klasické trojčlenky mi vyšlo 106 800 Kč, Techradar uvádí jeden přepočet na dolary - The company will release a 50-inch screen model that is only an inch in depth for 600,000 yen ($6,685).
Moc to neřeště, loňská řada TH-42PX80 startovala cca 230.000 JPY což je 61 410 Kč a tady se prodávala za 23 000 Kč, jestli mě paměť neklame, navíc je to doporučená cena a eshopy prodávají za méně viz. TH-P37X1, kde doporučená cena byla 180.000 JPY a prodává se
http://www.coneco.net/PriceList.asp?COM_ID=1090113065
kolemjdoucí
Příspěvekod kolemjdoucí v středa 4. 2. 2009 14:08:48
Whathifi informuje, že U.K. HD ready série se bude prodávat pod označením TX, takže pro Evropu by to mělo být stejné, ale hlavně uvádí předpokládané doporučené ceny těchto modelů pro U.K.
UK models and prices
So far, information on the UK-specific models is thin on the ground, but it seems that prices have been given to dealers for the following plasma models (now apparently called TX-, not TH- as in 2008):
TX-P37X10 (37in, £699)
TX-P42X10 (42in, £799)
TX-P50X10 (50in, £999)
kolemjdoucí
Příspěvekod kolemjdoucí v pátek 6. 2. 2009 22:42:39
Ani se mi to sem po té události s Pioneerem nechce dávat.....U.K. eshop Directtvs už má v nabídce řady X a ty ceny nejsou tak hrozné jak se jevilo při přepočtech z JPY,
TX-P37X10 - http://www.directtvs.co.uk/Panasonic_TX ... ersion.asp
TX-P42X10 - http://www.directtvs.co.uk/Panasonic_TX ... ersion.asp
TX-P50X10 - http://www.directtvs.co.uk/Panasonic_TX ... ersion.asp
kolemjdoucí
Příspěvekod Martas v sobota 7. 2. 2009 1:00:01
Tak koukam ze ani jedna z nich neni fullhd. :(
Martas
Příspěvekod fwefw v neděle 22. 2. 2009 16:40:38
Martas píše:Tak koukam ze ani jedna z nich neni fullhd. :(
PX10 bude asi náhrada za PX8.
fwefw
Příspěvekod johnym v neděle 22. 2. 2009 18:11:49
Pozor! Pre Europsky trh budu mat novy Neo-PDP panel len dve najvyssie rady, teda V10, Z1.
Ostatne modely z r2009 nebudu v Europe neo-PDP, na rozdiel od US.
johnym
Příspěvekod kolemjdoucí v pondělí 23. 2. 2009 12:16:25
Zítra a pozítří Panasonic oficiálně představuje své evropské modelové série pro letošní rok, tak uvidíme jak to s Neo PDP dopadne.
Dnes se na webu Panasonicu objevily série X10 i s doporučenými cenami
TX-P37X10E - 23 495,00 Kč
TX-P42X10E - 24 995,00 Kč
TX-P50X10E - 34 995,00 Kč
http://www.panasonic.cz/vyrobky.aspx?id=AAB
kolemjdoucí
Příspěvekod kolemjdoucí v čtvrtek 26. 2. 2009 10:23:14
Zdravím, napadlo mne.... ještě před oficiálním uvedením v Amsterdamu proskočily některými weby zprávy o MPEG-4 AVC tunerech, kterými mají být tyto tv vybaveny, no a na portugalském webu Panasonicu je k vidění série G10, které jej obsahují, + DVB-C.
http://www.panasonic-sonicel.com/Deskto ... tegory=207
Vzhledem k tomu, že jde o oficiální název série, taj se rýsuje naděje, že je budou obsahovat i tv, které budou v prodeji u nás.
Naposledy upravil kolemjdoucí dne sobota 28. 2. 2009 10:09:12, celkově upraveno 1
kolemjdoucí
Příspěvekod kolemjdoucí v čtvrtek 26. 2. 2009 20:49:08
Ještě doplním doporučené ceny v U.K., které se objevily na Whathifi.
S Series
42, 46 and 50in plasmas (£999, £tbc, £tbc)
G10 Series
42, 46 and 50in plasma (£1199, £1399, £1499)
G15 Series
42 and 46in plasma (£1299, £1499)
V10 Series
42 and 50in plasma (£1499, £1799)
http://whathifi.com/blogs/television/ar ... rices.aspx
kolemjdoucí
Příspěvekod johnym v sobota 28. 2. 2009 3:16:25
Dobra sprava- Z a V seria 2009 modelov Panasonic plaziem zobrazuje 24p na 96Hz . :)
Horsia sprava- kontrast nedosahuje uroven 9G Kura. Osobne mi to az tak nevadi. Uz 2008 modely mali akceptovatelne podanie ciernej, takze zlepsenie je super.
Rozhodujucim faktorom pre moju kupu bude podanie SD signalu.
johnym
Příspěvekod mordydy v sobota 7. 3. 2009 12:49:03
Nevíte, kde jsou uvedené zázraky u nás (v Praze) k vidění?
mordydy
Příspěvekod kolemjdoucí v středa 11. 3. 2009 13:32:34
Na webu Panasonicu se objevila první série Neo PDP
TX-P50G10E-54 995,00 Kč
TX-P46G10E-45 995,00 Kč
TX-P42G10E-36 995,00 Kč
kolemjdoucí
Příspěvekod guvi v středa 11. 3. 2009 14:13:19
Dobrý je, že mají vestavěný jak DVB-T tak DVB-S tuner, oba ve verzi MPEG2 i MPEG4.
guvi
Příspěvekod Martas v středa 11. 3. 2009 19:47:17
A ses si jistej s tim sat tunerem ja to totiz chapu jako ze tam neni teda.
Integrovaný analogový tuner •
DVB-T tuner MPEG-2 •
DVB-T tuner MPEG-4 •
DVB-S (satelitní) SD/HD -
ATP - automatické ladění a třídění • :)
Martas
Příspěvekod kolemjdoucí v středa 11. 3. 2009 20:27:56
Tak to změnili, ten sat tuner tam původně byl, dopoledne jsem koukal namátkou po Evropě a weby kde je k vidění série G10 - UK, Francie nebo Poláci uvádí u těchto TV Inteligent Frame Creation pro a u nás je pouze podpora 24p. Asi bude další změna.
http://www.panasonic.eu/
kolemjdoucí
Další
Zpět na Plazmové televizory
